Ein neues Thema erstellen  Auf das Thema antworten  [ 9 Beiträge ]
BeitragVerfasst: 03.01.2006, 07:37
HI , ich habe ein großes Problem nach jeden Map wechsek stürzt der Source Server ab ??
Source sErver Version : v1.0.0.25 (Linux, Dedicated)
Erweiterungen : Mani Admin Plugin v1.1.0zh, MetaMod v1.1.2
FEhler im cs.log habe ich gefunden und zwar diese ..
************ LOADING SKINS *************
Failed to load [admin_t.txt]
Above warning due to failed attempt to load custom map skin ./cfg/mani_admin_plugin/skins/maps/de_dust2/admin_t.txt
admin_t.txt
Failed to load [admin_ct.txt]
Above warning due to failed attempt to load custom map skin ./cfg/mani_admin_plugin/skins/maps/de_dust2/admin_ct.txt
admin_ct.txt
Failed to load [reserved_t.txt]
Above warning due to failed attempt to load custom map skin ./cfg/mani_admin_plugin/skins/maps/de_dust2/reserved_t.txt
reserved_t.txt
Failed to load [reserved_ct.txt]
Above warning due to failed attempt to load custom map skin ./cfg/mani_admin_plugin/skins/maps/de_dust2/reserved_ct.txt
reserved_ct.txt
Failed to load [public_t.txt]
Above warning due to failed attempt to load custom map skin ./cfg/mani_admin_plugin/skins/maps/de_dust2/public_t.txt
public_t.txt
Failed to load [public_ct.txt]
Above warning due to failed attempt to load custom map skin ./cfg/mani_admin_plugin/skins/maps/de_dust2/public_ct.txt
public_ct.txt
Failed to load [misc.txt]
Above warning due to failed attempt to load custom map skin ./cfg/mani_admin_plugin/skins/maps/de_dust2/misc.txt
misc.txt
************ SKINS LOADED *************
**** LOADING CUSTOM MODEL ACTIONS *****
Failed to load modelconfig.txt
und diesen
Mani Admin Plugin Level Init Time = 0.346 seconds
Executing dedicated server config file
Summary: 323 resources total 14.52 Mb, 21.64 % of capacity
Unknown command "ste,"
Unknown command "damerika,"
Unknown command "r"
Unknown command "r"
Unknown command "llig"
Unknown command "gung"
Unknown command "cher"
Unknown command "ber"
Unknown command "cs_stacking_num_levels"
Unknown command "nnen."
Unknown command "rbar"
Unknown command "llt."
Unknown command "ted"
Unknown command "nnen"
Unknown command "hen"
Unknown command "uft"
Unknown command "chsten"
Unknown command "ssenausgleich."
Unknown command "mp_forcechasecam"
Unknown command "r"
Unknown command "tete"
Unknown command "r"
Unknown command "glich"
Unknown command "nde"
Unknown command "r"
Unknown command "r"
Unknown command "rbar."
Unknown command "r"
Unknown command "sv_voicequality"
Unknown command "t"
Unknown command "bertragung"
Unknown command "gbare"
Unknown command "r"
Unknown command "r"
Unknown command "ndert"
Unknown command "rke"
Unknown
SO sieht das log aus und wenn ich nun einen map wecksel mache ist er wieder TOT und ich denke mal das ich ein Problem mit den Custem Models habe die ich mal instelliert habe das waren die Iduke Models wie bekomme ich das nun wieder hin ??
BeitragVerfasst: 03.01.2006, 08:45
NACHTRAG :
Ich habe das Mani Pluign mal raus genommen dann läuft der server auch wieder aber ich habe dann im Log auch noch diesen eintrag
Console initialized.
Attempted to create unknown entity type event_queue_saveload_proxy!
Game.dll loaded for "Counter-Strike: Source"
maxplayers set to 32
Unknown command "mani_reverse_admin_flags"
Unknown command "mani_reverse_immunity_flags"
Unknown command "port"
maxplayers set to 12
Network: IP 85.131.253.14, mode MP, dedicated Yes, ports 27700 SV / 27008 CL
Unknown command "r"
Unknown command "r"
Und das geht noch weiter also mit dem Unknow Command was hat dies denn noch zu bedeuten ???
BeitragVerfasst: 04.01.2006, 16:15
Offenbar fehlen einige Dateien in dem Verzeichnis /cfg/mani_admin_plugin/skins
Vielleicht solltest Du es mal ohne das Metamod Plugin versuchen. Mani Admin Plugin ist darauf nicht angewiesen, sondern arbeitet direkt mit dem HL² Server.
Fuer die Unknown Commands waere vielleicht die server.cfg hilfreich.
BeitragVerfasst: 04.01.2006, 17:39
Hmm also ohne meta mod läuft es :) ...
Anbei mal die Server.cfg von mir auch habe ich nun das Problem das die Bots nicht mehr auf den server kommen hatte das so das 3 Bots kommen sobalt ein Spieler on ist und dann wenn ein Mensch dazu kommt wieder einer geht dies lief immer nun kommt aber kein Bot mehr auch mit addbot geht da nix .. ???
Anbei die server.cfg
server.rar [5.53 KiB]
849-mal heruntergeladen
BeitragVerfasst: 06.01.2006, 22:11
Bezueglich der Bots sieht die server.cfg eigentlich ganz gut aus.
Die cvar
// bot_add
hast Du auskommentiert. Vielleicht solltest Du sie versuchsweise einkommentieren. Garantie kann ich Dir dafuer aber nicht geben, dafuer ist die ganze HL² Geschichte immer noch zu unberechenbar. :roll:
BeitragVerfasst: 07.01.2006, 15:57
Hi , thx für den tip aber da passiert denoch nix ???
BeitragVerfasst: 08.01.2006, 14:45
mit bot_join_after_player 1 funktioniert bot_add erst, wenn ein Spieler auf dem Server ist
BeitragVerfasst: 10.01.2006, 09:45
Hi , geht auch nicht ;( ...
Also die Bots kommen nicht ..
BeitragVerfasst: 10.01.2006, 22:08
Auch bei Standardmaps? Evtl. hat er keine nav-Dateien..
