Ein neues Thema erstellen  Auf das Thema antworten  [ 6 Beiträge ]
 Betreff des Beitrags: Plugin_tagprotect
BeitragVerfasst: 30.07.2003, 21:06
wie kann ich es umschreiben, dass die tags.txt in
addons/adminmod/config/tagprotect
kommt?
oder kann es einer neuschreiben? kick und namechange reicht...
 Protect Tag by redeyez (redeyez@mindspring.com)
 Protect Clan Tags and/or Player names to certain WonID
 History:
 version 1.2 - Implemented the Command option.
		   Added more (rather verbose) Debug comments.
		   Removed some junk.
 version 1.1 - Fixed a cuple of bugs.
		   Add Command option in Tags.txt file
		   Not implemented yet.
 version 1.0 - First release of Protect Tag Plugin.
#include <core>
#include <console>
#include <string>
#include <admin>
#include <adminlib>
#define ACCESS_PROTECTTAG 8192
#define MAX_TAGS 100
new STRING_VERSION[MAX_DATA_LENGTH] = "1.2";
new TagTimer[MAX_PLAYERS];
new FileStatus = 0; /* Check if file exists flag */
new TotalTags = 0;
new ClanTag[MAX_TAGS][MAX_TEXT_LENGTH];
new Command[MAX_TAGS];
new TagType[MAX_TAGS];
new PlayerWonID[MAX_TAGS][MAX_TEXT_LENGTH];
new DebugUser[MAX_NAME_LENGTH];
new DebugFlag = 0;
public tag_debug (HLCommand, HLData, HLUserName, UserIndex)
	convert_string(HLUserName, DebugUser, MAX_NAME_LENGTH);
	if (DebugFlag)
		printf ("[PROTECT TAG] Debug Off^n");
		messageex(DebugUser,"[PROTECT TAG] Debug Off",print_console);
		DebugFlag = 0;
	else
		printf ("[PROTECT TAG] Debug On^n");
		messageex(DebugUser,"[PROTECT TAG] Debug On",print_console);
		DebugFlag = 1;
	return PLUGIN_HANDLED;
public load_tag_file()
	new gotLine;
	new lineNum = 0;
	new lineStr[MAX_TEXT_LENGTH];
	new Text[MAX_TEXT_LENGTH];
	TotalTags = 0;
	FileStatus = fileexists("TAGS.TXT");
	if ( FileStatus > 0 )
		printf("[TAG PROTECT]Reading Tags.^n");
		do
			gotLine = readfile("TAGS.TXT",lineStr, lineNum, MAX_TEXT_LENGTH);
			if (gotLine)
				if (DebugFlag)
					printf ("Got tag %s^n",lineStr);
					printf ("Got Line # %s^n",TotalTags+1);
				lineNum++;
				if ((strncmp(lineStr, "#", 1) == 0) || (strncmp(lineStr, "//", 2) == 0))
					/* Ignoreing comment. */
				else
					strsplit(lineStr, ";", TagType[TotalTags], MAX_DATA_LENGTH , Command[TotalTags], MAX_DATA_LENGTH , ClanTag[TotalTags], MAX_DATA_LENGTH, PlayerWonID[TotalTags], MAX_DATA_LENGTH);
					TagType[TotalTags] = strtonum(TagType[TotalTags]);
					Command[TotalTags] = strtonum(Command[TotalTags]);
					if (DebugFlag)
						printf("TAG: %s WONID: %s COMMAND: %i TAGTYPE: %i^n",ClanTag[TotalTags],PlayerWonID[TotalTags],Command[TotalTags],TagType[TotalTags]);
					TotalTags++;
			if ( TotalTags > MAX_TAGS )
				return PLUGIN_CONTINUE;
		} while(gotLine);
		TotalTags--;
		snprintf(Text, MAX_TEXT_LENGTH, "[PROTECT TAG] TAGS.TXT file found: %i Tags",TotalTags);
		printf ("%s.^n",Text);
		if (DebugFlag)
			messageex(DebugUser,Text,print_console);
	else
		printf ("[PROTECT TAG] Cannot find TAGS.TXT file.^n");
		if (DebugFlag)
			messageex(DebugUser,"[PROTECT TAG] Cannot find TAGS.TXT file.",print_console);
public  TagTrigger(Timer,WaitCount,RepeatCount,User) {
	new MyWONID;
	new UserIndex;
	new MyName[MAX_NAME_LENGTH];
	new searchIndex = 0;
	new NameFound = 0;
	new TagFound = 0;
	new TagCommand = 0;
	convert_string(User, MyName, MAX_NAME_LENGTH);
	get_userindex(MyName, UserIndex);
	get_userWONID(MyName, MyWONID);
	/* Only continue if player has fully connected; WONID of 0 means they haven't */
	if ( MyWONID != 0 )
		if (DebugFlag)
			messageex(MyName,"[PROTECT TAG] AUTHENTICATING CLAN TAG...",print_console);
			printf ("%s",Text);
		for ( searchIndex=1; searchIndex<=TotalTags; searchIndex++ )
			if (TagType[searchIndex] == 0 )
				if ( (strcasestr(MyName,ClanTag[searchIndex]) != -1) )
					if (DebugFlag)
						messageex(MyName,"^n[PROTECT TAG] TAG MATCH",print_console);
						snprintf(Text, MAX_TEXT_LENGTH, "^nsearchIndex: %i ClanTag: %s YourName: %s",searchIndex, ClanTag[searchIndex], MyName);
						messageex(MyName, Text, print_console);
					if (MyWONID == strtonum(PlayerWonID[searchIndex]))
						TagFound = 1;
						if (DebugFlag)
							messageex(MyName,"AUTHENICATED",print_console);
						searchIndex=TotalTags+1;
					else
						TagFound = 2;
						if ( Command[searchIndex] > TagCommand )
							TagCommand = Command[searchIndex];
		if (DebugFlag)
			if ( TagFound == 2 )
				messageex(MyName, "FAILED TO AUTHENICATE",print_console);
				printf ("%s^n",Text);
			if ( TagFound == 0 )
				messageex(MyName, "DONE",print_console);
			messageex(MyName,"[PROTECT TAG] AUTHENTICATING NAME...",print_console);
			printf ("%s",Text);
			if (TagType[searchIndex] == 1 )
					if (DebugFlag)
						messageex(MyName,"^n[PROTECT TAG] NAME MATCH",print_console);
						NameFound = 1;
						if (DebugFlag)
					else
						NameFound = 2;
		if (DebugFlag)
			if ( NameFound == 2 )
			if ( NameFound == 0 )
		if ( (TagFound == 2) || (NameFound == 2) )
			if ( TagCommand != 1 && TagCommand != 2 )
				execclient(MyName, "name IMPOSTER");
			if ( TagCommand == 1 )
				kick(MyName);
			if ( TagCommand == 2 )
				ban(MyName,0);
		kill_timer(TagTimer[UserIndex]);
	else
		/* Repeat later when the player has hopefully finished connecting */
		if ( TagTimer[UserIndex] != 0 ) kill_timer(TagTimer[UserIndex]);
		TagTimer[UserIndex] = set_timer("TagTrigger",30,0,MyName);
public plugin_connect(HLUserName, HLIP, UserIndex)
	new MyUserName[MAX_NAME_LENGTH];
	convert_string(HLUserName, MyUserName, MAX_NAME_LENGTH);
	if ( (UserIndex >= 1) && (UserIndex <= MAX_PLAYERS))
		TagTimer[UserIndex] = set_timer("TagTrigger",30,0,MyUserName);
public plugin_disconnect(HLUserName, UserIndex) {
	if ( UserIndex >= 1 && UserIndex <= MAX_PLAYERS )
public plugin_info(HLOldName,HLNewName,UserIndex)
	new MyWONID;
	new NewName[MAX_NAME_LENGTH];
	new OldName[MAX_NAME_LENGTH];
	new NameFound = 0;
	new TagFound = 0;
	new TagCommand = 0;
	convert_string(HLNewName, NewName, MAX_NAME_LENGTH);
	convert_string(HLOldName, OldName, MAX_NAME_LENGTH);
	get_userWONID(OldName, MyWONID);
	/* Only bother if the name has changed. */
	if(streq(OldName,NewName)==0)
		if (DebugFlag)
			messageex(OldName,"[PROTECT TAG] YOUR NAME HAS CHANGED",print_console);
		if ( (strcasestr(NewName,"IMPOSTER") != -1) )
		if (DebugFlag)
			messageex(OldName,"[PROTECT TAG] AUTHENTICATING CLAN TAG...",print_console);
			printf ("%s",Text);
				if ( (strcasestr(NewName,ClanTag[searchIndex]) != -1) )
					if (DebugFlag)
						messageex(OldName,"^n[PROTECT TAG] TAG MATCH",print_console);
						snprintf(Text, MAX_TEXT_LENGTH, "^nsearchIndex: %i ClanTag: %s YourName: %s",searchIndex, ClanTag[searchIndex], NewName);
						messageex(OldName, Text, print_chat);
						TagFound = 1;
						if (DebugFlag)
							messageex(OldName,"AUTHENICATED",print_console);
					else
						TagFound = 2;
		if (DebugFlag)
				messageex(OldName, "FAILED TO AUTHENICATE",print_console);
				messageex(OldName, "DONE",print_console);
			messageex(OldName,"[PROTECT TAG] AUTHENTICATING NAME...",print_console);
			printf ("%s",Text);
					if (DebugFlag)
						messageex(OldName,"^n[PROTECT TAG] NAME MATCH",print_console);
						messageex(OldName, Text, print_console);
						NameFound = 1;
						if (DebugFlag)
					else
						NameFound = 2;
		if (DebugFlag)
				execclient(OldName, "name IMPOSTER");
				kick(OldName);
				ban(OldName,0);
public plugin_init()
	plugin_registerinfo("Protect Clan Tags Plugin", "Protect Clan Tags.", STRING_VERSION);
	plugin_registercmd("admin_loadtags", "load_tag_file", ACCESS_PROTECTTAG);
	plugin_registercmd("admin_tagdebug", "tag_debug",ACCESS_PROTECTTAG);
	load_tag_file();
BeitragVerfasst: 30.07.2003, 21:20
Mit meinen begrenzten Kenntnissen wuerde ich mal sagen, dass Du die Zeile
auf das gewuenschte Verzeichnis editieren musst.
Sie befindet sich in der public load_tag_file() Funktion.
Keine Garantie :roll:
greez
[-=THH=-]Stillsetzhut
BeitragVerfasst: 30.07.2003, 21:22
die hier auch
BeitragVerfasst: 30.07.2003, 23:22
Dürfte ich mal fragen, warum Du so ein Plugin brauchst? Du hast doch schon mit Regex einen Tag-Protect eingerichtet.
BeitragVerfasst: 31.07.2003, 07:18
ja, hat auch mit regex wunderbar funktioniert...
gab aber paar problemchen... beim mapchange bin ich z.B. rausgeflogen wegen "nickname reserviert" - ein retry hat auch nix genutzt... musste ganz raus und wieder neu connecten...
aber sonst ging es auch mit regex... nur scheint mir das plugin die einfachere wahl zu sein... ich trage nur die wonid`s in die tags.txt und fertig...
bin eher der "test-typ" - halte mir mehrere optionen offen und teste die einfachste...
BeitragVerfasst: 31.07.2003, 12:59
funzt bei mir net richtig... scheint beim kick probleme zu haben...
habs aber geändert bekommen, mit der tags.txt... :lol:
nur funzt es nicht... kann mal einer bei sich testen?
ausserdem kommt ne compillerwarnung:
#include <core>
#include <console>
#include <string>
#include <admin>
#include <adminlib>
new TotalTags = 0;
new DebugFlag = 0;
	if (DebugFlag)
		DebugFlag = 0;
	else
		DebugFlag = 1;
	new gotLine;
	new lineNum = 0;
	TotalTags = 0;
	FileStatus = fileexists("addons/adminmod/config/tags/tags.txt");
		do
			gotLine = readfile("addons/adminmod/config/tags/tags.txt",lineStr, lineNum, MAX_TEXT_LENGTH);
			if (gotLine)
				if (DebugFlag)
				lineNum++;
				else
					if (DebugFlag)
					TotalTags++;
		} while(gotLine);
		TotalTags--;
		if (DebugFlag)
	else
		if (DebugFlag)
	new MyWONID;
	new UserIndex;
	new NameFound = 0;
	new TagFound = 0;
	new TagCommand = 0;
	if ( MyWONID != 0 )
		if (DebugFlag)
			printf ("%s",Text);
					if (DebugFlag)
						TagFound = 1;
						if (DebugFlag)
					else
						TagFound = 2;
		if (DebugFlag)
			printf ("%s",Text);
					if (DebugFlag)
						NameFound = 1;
						if (DebugFlag)
					else
						NameFound = 2;
		if (DebugFlag)
				kick(MyName);
				ban(MyName,0);
	else
	new MyWONID;
	new NameFound = 0;
	new TagFound = 0;
	new TagCommand = 0;
		if (DebugFlag)
		if (DebugFlag)
			printf ("%s",Text);
					if (DebugFlag)
						TagFound = 1;
						if (DebugFlag)
					else
						TagFound = 2;
		if (DebugFlag)
			printf ("%s",Text);
					if (DebugFlag)
						NameFound = 1;
						if (DebugFlag)
					else
						NameFound = 2;
		if (DebugFlag)
				kick(OldName);
				ban(OldName,0);
	load_tag_file();
un die tags.txt angehängt:
tags.txt [1.54 KiB]
620-mal heruntergeladen
